Testing and Results
We measure the CPU temperature of our test rigs when the CPU is idle (Windows desktop) and under load (by running the smallfft test in
Prime95). We use the freeware application
CoreTemp to measure the temperature of the Intel CPUs, which reads the data from the DTS (digital thermal sensor) embedded in the core of every modern CPU. The DTS gives a far more accurate reading than any third-party temperature sensor, because its readings are not affected by sloppy BIOS programming or a poorly calibrated external health monitoring chip on the motherboard.
Because we don't have a temperature control chamber, it's more accurate to measure and quote the delta T (difference) between the ambient and CPU temperature. This means HSFs (heatsinks and fans) that were tested on different days, when the ambient temperature may have varied, can be fairly compared to one another. You'll find the temperature results for the reference HSFs in the graphs. We normally compare the results of each cooler to the reference cooler.
However for the Socket AM3+ and LGA2011 systems, we didn't have the reference coolers for these at time of testing, so the cooling scores are compared against other coolers rather than how much better the cooler was than the reference cooler.
 LGA1155 test system:- Core i7-2600K overclocked to 4.1GHz using a vcore of 1.325V
LGA2011 test system:- Core i7-3960X Extreme Edition overclocked to 4.3GHz using a vcore of 1.285V
 Each test rig is built inside a SilverStone PS03 midi-tower case and includes an Nvidia GeForce 9600 GT graphics card. The temperatures shown are the delta T between ambient and CPU temperature.
Please note that, unfortunately, our AMD test system has keeled over and died. While we are currently working on a replacement, we have only had the opportunity to test the ETS-T40-TA in our two Intel systems.
        Corsair H100i Maximum Profile
        Corsair H100i Balanced Profile
        Corsair H80i Maximum Profile (exhaust)
        Corsair H80i Maximum Profile (intake)
        Corsair H100i Quiet Profile
        Corsair H80 full speed
        Corsair H100 full speed
        Thermaltake Water 2.0 Pro
        Corsair H80i Balanced Profile (intake)
        Antec Kühler H2O 920 (Extreme Profile)
        Corsair H100 medium speed
        Corsair H80i Balanced Profile (exhaust)
        Thermaltake Water 2.0 Performer
        Corsair H80 medium speed
        Arctic Freezer i30
        Be Quiet! Dark Rock Pro 2
        Phanteks PH-TC14PE full speed
        Thermalright Macho Rev.A
        Corsair H80i Quiet Profile (intake)
        Corsair H100 low speed
        Be Quiet Dark Rock Pro
        Zalman CNPS14X
        Corsair H80i Quiet Profile (exhaust)
        Enermax ETS-T40-TA
        Corsair H80 low speed
        Phanteks PH-TC14PE low speed
        Be Quiet! Dark Rock Advanced
        Gelid Tranquillo Rev2
        Gelid GX-7
        Thermolab Trinity high speed
        Antec Kühler H2O 920 (Silent Profile)
        Thermolab Trinity low speed
        Intel Reference Cooler
          20
          30
          40
          50
          60
          70
          80
    Delta T (°C) (lower is better)
        Thermaltake Frio Advanced
        Intel Thermal Solution RTS2011LC
        Arctic Freezer i30
        Zalman CNPS14X
        Be Quiet Dark Rock Pro (with LGA2011 mount kit)
        Enermax ETS-T40-TA
Head
over the page to see the performance analysis and scores
